BV10: enable the TV Setup menu - How?
This post has 3 Replies | 0 Followers
kimhav
Malmo, Sweden
Posts 314
kimhav Posted: Sun, Dec 8 2019 7:10 PM
I've previously disabled the analogue TV tuner since as most other, I don't utilise any analogue input. But, I now realise that I'm not able to enter the BV10 Service Menu (MENU,0,0) or the TV Setup due to that when I press the TV on the remote it's then acts as DTV...
How do one re-enable the TV Setup menu function so one can access it again?
Also, when trying to go for the Customer Service Menu by pressing RED + GO while the cursor is placed on the CONNECTIONS field isn't possible either since I can't locate the connection field which I assume is in the TV Setup menu, or?
BOBrb
Posts 88
BOBrb replied on Mon, Dec 9 2019 4:15 PM
Simply press the menu button twice
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Tue, Dec 10 2019 7:43 PM
Hrm... Okey, that was easy... once you know it. Big thanks for quick response.
BOBrb
Posts 88
BOBrb replied on Thu, Dec 12 2019 4:43 PM
Big Smile
Page 1 of 1 (4 items) | RSS
