Does the 280w mean how loud it will go? It just doesn’t seem to be quite loud enough for me, other than that great quality
That is just a specification (the socalled peak output) - in reality it says little about how load and (more important) how ‘good’ the sound is at a certain volume.
’doesn’t seem to be loud enough....’ - what do you expect from a small bluetooth speaker???
In general people seem to be quite content with how the A1 performs!
It's pretty loud for something the size of a hamburger. Not sure what more you could expect from something that small.
I am using A1 mostly in my sailboat cockpit.And it sounds much better than built-in marine speakers.
Btw,what B&O speakers would be best for boat cabin use,apart of portable speakers? Boat owners,please advice !
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Just seen video about pairing two A1's stereo to android phone.So,I will just buy one more A1.
