I just checked the manually downloadable system drivers on the BLGW and saw a new driver: MasterLink Gateway Protocol driver. The description merely says "MasterLink compatibility using a BLGW or a MLGW as interface." However, is states that it is incompatible for installation and requires v2.1.0 or newer.
Could this be the solution that Khimo had suggested might be coming for better integration of ML products with the BLI?
