All,
H.
shinobi52:Hi Hero! I've also the app and don't have any crashes. Delete it and make the installation again, may be it will help? To change the channels, you have a plus and minus on each side Of the screen. With two finger swipe on the down of the screen, you will see the others screens. Check the vidéo on YouTube or on the v1 thread of the forum. You'll understand how it works.
I'll have a look. Thanks for your feedback.
shinobi52: For the 99€, I find it also a little bit expansive for what it is. May be you can negociate with your dealer?
I'm not buying into this scam.
The "Smart" thing to do here is to get an Apple TV for the same amount of money and you have a ton more features.
I'm not going to bother for the time being either. It is more expensive than the Apple TV and the only other thing it offers (iPlayer) I have on my PS3, although I do admit that a slick native application for this (and 4OD!) within the V1 would be great.
jkhamler:I'm not going to bother for the time being either. It is more expensive than the Apple TV and the only other thing it offers (iPlayer) I have on my PS3, although I do admit that a slick native application for this (and 4OD!) within the V1 would be great.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Crash demo: http://youtu.be/2QYvahfyMB4
Hero71: shinobi52:Hi Hero! I've also the app and don't have any crashes. Delete it and make the installation again, may be it will help? To change the channels, you have a plus and minus on each side Of the screen. With two finger swipe on the down of the screen, you will see the others screens. Check the vidéo on YouTube or on the v1 thread of the forum. You'll understand how it works. Crash demo: http://youtu.be/2QYvahfyMB4
as per my feedback on the other thread - check your network settings such as password access.
BeoNut since '75
What ipad version do you have? If its is a generation 1 it might not have enough memory .....
jk1002:What ipad version do you have? If its is a generation 1 it might not have enough memory .....
elephant: as per my feedback on the other thread - check your network settings such as password access.
Network connection is fine. If the app could not find any compatible B&O device, you would not see the the source list and you would get an error saying that the app cannot find any compatible B&O hardware.
My app launches and shows the correct available sources but when I select a source, the V1 switches to that source but the app immediately crashes.
Hero71: elephant: as per my feedback on the other thread - check your network settings such as password access. Network connection is fine. If the app could not find any compatible B&O device, you would not see the the source list and you would get an error saying that the app cannot find any compatible B&O hardware. My app launches and shows the correct available sources but when I select a source, the V1 switches to that source but the app immediately crashes.
hmmm
The alternative the memory theory would only make sense if the source was "flooding" the App with a large amount of data - I don't see that the V1 would be doing that.
The youtube clip you made was a bit fuzzy, and I don't know the V1's interface, so I can't make out what were the functions you were trying to start.
The fact that the V1 responds is something of a good sign.
What were the functions you were trying that the V1 responds to ?
From my experience with chrashng Apps...a reboot of the iPad often helps.
i am using the b&o App. with an ipad3 without any Problems.
kiwi4all: From my experience with chrashng Apps...a reboot of the iPad often helps. i am using the b&o App. with an ipad3 without any Problems.
That did not work. Neither does re-intallating the BeoRemote app, nor wiping my iPad and restoring it again. It just doesn't work.
