Moment Users Help Pls? Issues with Beosound Moment and Twonky Server "can't connect to the server"
This post has 9 Replies | 0 Followers
mmctsai
Posts 20
mmctsai Posted: Wed, Nov 13 2019 2:02 AM
Dear all, I have set up my besound moment with Twonky server on iMac and working for a while, recently the server stop responding and when I checked the server setting, it says error on server. I googled and tried resetting besound moment, reinstalled twonky app (mac), now when I click twonky server setting, the error message says Safari can't connect to the server "127.0.0.1:0"
Has everyone encounter similar issue before and any guidance to repair this? thanks guys.
Regards,
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Nov 13 2019 8:56 AM
Usually Twonky listens on port 9000. Try http://127.0.0.1:9000/webconfig
If you cannot reach it via the web interface, the Moment will have no luck reaching it too.
Have you change something in your iMac recently? O/S upgrade, Firewall software?
KR
mmctsai
Posts 20
mmctsai replied on Wed, Nov 13 2019 11:12 AM
Thanks for your prompt assistance, I tried 9000 and it still wouldn’t connect.....
Regarding changes, the server stop responding with no reason and no changes at first, so I updated iMac to the lastest OS and reinstall Twonky app and this is where I stuck now. My question is when I first bought and set up moment and Twonky app, it did ask me for the activation key and relevant beginning set up when I launch the app, this time when I reinstalled the app, nothing at all, the app just launch by itself and can’t connect. Where can I delete the root file to fresh reinstall again? Thanks in advance.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Nov 13 2019 8:31 PM
mmctsai:
The only version I have tested on a Mac is 8.5.1 which relies on a connection to a server for the license, but looking at the application packet, I see a CleanTwonkyServerData.command in the arborescence, maybe you have the same, have a look.
That said, Twonky is no longer supported, the only remaining useful information is the Twonky user forum (https://forum.twonky.com/viewforum.php?f=2).
If you only use Twonky as a DLNA server, and don't leverage it's Photo support to manage your own artist tile images on the Moment, then you could eventually switch to another DLNA server like Minimserver, free and efficient, while a little bit more techie
mmctsai
Posts 20
mmctsai replied on Thu, Nov 14 2019 12:41 AM
Thanks again for your prompt assistance, may I know where to check the version of my twonky app? it is the current download from B&O and could anyone guide me how to check cleantwonkyserverdata.command?
I read and heard Twonky is no longer supporting B&O, I am wondering if any other Moment users still working well with their iTunes/twonky app? thanks guys.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Nov 14 2019 9:16 AM
mmctsai:
It is not about Twonky no longer supporting B&O but about Twonky application no longer being developed/supported.
You can find the version by right clicking on the app file in your finder and look for more information, version number should be identifiable in the panel.
By right clicking the app icon you can also open the packet and look for the reset data command.
mmctsai
Posts 20
mmctsai replied on Tue, Nov 19 2019 4:39 AM
Thanks again for your assistance, I have right clicked the app and found out my twonky app is Version 7.2, this app was the latest from B&O website,
https://www.bang-olufsen.com/en/product-support/accessories/media-server
May I know where you got your version 8 from? pls kindly share download link?
I couldn't figure out how to find reset data command......
May I check with every moment users if your twonky app still work with your moment? thanks guys
mmctsai
Posts 20
mmctsai replied on Fri, Nov 22 2019 2:19 AM
To all moment users, pls kindly advice if your moment is still working with Twonky server? thanks everyone.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 22 2019 10:00 AM
Your issue is not the Moment but your Twonky server app that does not start property, according to what you described.
mmctsai
Posts 20
mmctsai replied on Mon, Jan 13 2020 5:58 AM
Dear all, I had been contacting B&O customer service and they confirmed that moment no longer supported by twonky. As the original download link has been taken down, may I check if there is any kind soul still have the installation file for mac? thanks
Page 1 of 1 (10 items) | RSS
