Hello,
As above... I can't get stand to work... Is there a plug/connector? If so does anybody know where it is connected to.
Rgds
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Connector on the base goes via cable to inside the BS3. Sometimes the small wires can break at the connector at the base-side.
Many thanks.... Now I have a clue where to look.
wires are very fragile, or the TV has spun too far manually and popped out of the mechanism to rotate
