Beovision 5 STB-C
This post has 8 Replies | 3 Followers
Guy
Warwickshire
Posts 2,590
Guy Posted: Tue, Oct 30 2012 9:06 AM
If I buy a Beovision 5 to replace my Beovision 3, will the relatively new STB-C chip that I fitted in the BV3 transfer across to the BV5 - ie. are the STB-C modules the same?
I think the answer is 'yes' - can anyone confirm?
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Oct 30 2012 1:40 PM
It will - probably - depend on the TV's chassis (If your BV3 is the 32 inch version).
Found this:
So, is someone able to confirm?
Best regards
Ralf
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Oct 30 2012 2:37 PM
Many thanks Ralf,
Yes mine's a 3-32 so it looks like it would be OK
Guy
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Oct 30 2012 3:12 PM
I'm also in agreement that the Avant RF 32, BV3 32 and BV5 all shared the same chassis.
The RF 28 and BV3 28 were (I believe) a variant of the BeoVision 1 chassis !!
Lee
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Oct 30 2012 5:50 PM
Thanks Lee!
DoubleU
Posts 562
DoubleU replied on Tue, Oct 30 2012 7:17 PM
The chassis is not relevant when it comes to the STB-C chip. You can even transfer the chip to an old MX7000 if there is an STB-controller in it. They are all the same. Wink
So yes, you are good to go!
kai
Posts 362
kai replied on Tue, Oct 30 2012 10:54 PM
I have the beovision 5 controlling a sky box and a freeview works very well but if I'm watching sky on the beovision 5, if someone on the link tv bvis 7 it changes the main tv to the freeview?? Is that correct
Stoobietoo
Exeter, Devon, UK
Posts 692
Be very careful at swapping out the STB controller. I bought a second-life BV5 from a dealer and as part of the deal they agreed to update the controller so I could use a Humax PVR. They ended up having to replace the whole chassis because the STB chip would not be recognised by the TV.
I actually felt quite sorry for the dealer and the technician because they were excellent throughout, but what started as a simple goodwill gesture cost them a good 6 weeks of to-ing & fro-ing and I'd bought it from a dealer 90 miles away! They were determined to solve it and at one stage I listened in on a call to B&O HQ as they had not come across the issue and they were trying all sorts of suggestions while I watched my TV opened and closed up time after time.
In the end it was all to do with  the TV serial number and getting the STB chip to recognise it. They tried 3 chips so knew it must be the TV, they tried to re-program the serial number in my chassis and it did not work so a new chassis was installed and the memory cleared and re programmed and it worked.
Not that you will definitely have that problem, but something to think about when changing the chip yourself.
Stoobie
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Oct 31 2012 5:18 PM
Thanks Stoobie, that's very useful to know.
I am not sure that I want to rush into changing my BV3, it's actually working well and the picture's great.  I may wait until it goes wrong and then see what I can afford, maybe replacing it with the same, or perhaps a BV10 if secondhand prices keep going down!
Regards Guy
Page 1 of 1 (9 items) | RSS
