Hello,
I have a quick question if anyone can help please, Previously the subs like Beolab 2 or Beolab 11 had the PL links one in and two out. With Beolab 19 there is only 1 PL in.
If I want to connect my 18s to my beosound 5 encore, how do I connect the beolab 19? is it just connected to one of the beolab 18s?
Thanks for your help.
Yes. If positioning in the room (for most-even bass response) makes that cable ugly or impractical, you can run its own: See @Mikipidia's answer -- with a photo of a genuine B&O Powerlink splitter -- to a similar question about Beolab 28's:
https://archivedforum2.beoworld.org/forums/p/46642/348936.aspx#348936
