Master Control Panel 5000 fault
mshulan
Posts 1
mshulan Posted: Sun, Oct 5 2014 12:19 AM
My MCP 5000 has started exhibiting the following behavior: when I insert the batteries, it works fine for however many commands, key presses and functions I make in sequence, as long as I do not let the unit go to sleep.  When it does go to sleep I have to take the batteries out and reinsert them to "wake it up": there is no acitivity at all (no lights, notices or response of any kind) until I remove and reset the batteries. The batteries are brand new: the contacts are clean. I assume this is a bad power or power-saving relay of some sort (and that probably I need to get another unit on ebay, alas). Does this seem right?  The unit works fine other than this, which it has just started doing.  Any thoughts would be very much appreciated....
DMacri
United States
Posts 881
DMacri replied on Tue, Oct 7 2014 11:56 AM
I have one that does the same thing. I put it off to the side and bought a new one. I'd be interested in what you find.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
cjjones
Posts 3
cjjones replied on Sat, Jan 18 2020 6:24 PM
Hi there, I know this is a very old post! but did you ever resolve the issue?
Page 1 of 1 (3 items) | RSS
