I am original owner of Beolit 600 Type 1501. I bought it from Heals London UK in 1975.
Can anyone point me in the right direction for
1. New aerial,
2 The buttons for Volume and tone,
3. the ball bearings and side tuner.
4 2 new sides
5. Lower plate that holds the sides on.
6. 3 pegs that hold base plate on
Tks Will
Rileywill: I am original owner of Beolit 600 Type 1501. I bought it from Heals London UK in 1975. Can anyone point me in the right direction for 1. New aerial, 2 The buttons for Volume and tone, 3. the ball bearings and side tuner. 4 2 new sides 5. Lower plate that holds the sides on. 6. 3 pegs that hold base plate on Tks Will
Finding new parts will be impossible.You can hope for good used parts but, having said that, most of the parts you ask about seems to be missing everywhere.
