First of all, most of us dont upgrade to anything but original, your Beocord was state of the art when it came out, at that time near studio equipment.
If your tone heads are ok they will probably last for some more year, if worn they mostly can be restored. most important things is to keep the recorder clean, mechanics lubricated and well adjusted according to manual. Get yourself a new set of belts,and dont use or buy old tapes, buy good quality new ones.
Your recorder is analog and it will never be digital so 24 bit and 192 khz is not an option, but it will record and playback almost anything between 20 and 18000 Hz with a tape speed at 19 cm/sec. I have a Beocord 2000 and a Beocord 1200
I managed to pick up a mint condition, fully operational Beocord 1200 complete with rubber caps and dust cover on eBay for £105. Not a device I use very often, but it has stunning looks and great sound quality.
As Søren already wrote: Those old Beocords were high-end when they were manufactured back then.And they can be high-end again - (analogue, offcourse - forget about bits and bytes ) -when carefully restored. As Søren wrote: new belts, some lubrication -and maybe some new caps (capacitors).The famous producer Jeff Lynne (ELO), who has been producer for Traveling Wilbury's, George Harrison, Paul McCartney, Tom Petty and many more, started his career with a Beocord 2000 Deluxe:
"Some time in or after 1965, he acquired his first item of studio recording equipment, a Bang & Olufsen 'Beocord 2000 De Luxe' stereo reel-to-reel tape recorder, which allowed multi-tracking between left and right channels. He says it "taught me how to be a producer".http://www.radioswisspop.ch/en/music-database/musician/9210119db9c8c7ad69b05381fd380fce0f4e3d/biography
Change all electrolytic capacitors and trimmers, if not bad now they will go bad eventually, there is no need to change all components on the PCBs,
Slip clotches, no new ones to buy, clean, lubricate and adjust according to manual, get new belts from Dillen on this forum, they are special made to specifications and comes with instructions
Tapes, I use these bought on Amazon US
I'm surprised no one has mentioned the tools you'll need to maintain things after it's up and running, mainly tape head cleaner, foam swabs for cleaning heads and the tape path, and a demagnetizer/degausser to periodically demagnetize the tape path/heads. Also, if you're going to ever splice tapes you'll need splicing tape and a tape splicing block and razor blades to do that.
Jeff
Hi - I have a four reel to reel tape recorders and in my experience:
Reel to Reel tape recorders though are great fun to use, listen too and watch while the reels go round. In some ways CD's recorded onto tape, particularly music from before the 1970's sounds better to me on reel to reel as it introduces that analogue sound.
I'm sure you will have years of enjoyment with reel to reel and wish you well with it.
By the way - does anyone know if the B&O reel to reels based on Tandberg machines as the play and rewind controls look very similar? I beleive the Tandbergs were very good and reliable so wouldn't be surprised if B&O used their transports - but of course I could be totally wrong - interesting to know.
Andrew: By the way - does anyone know if the B&O reel to reels based on Tandberg machines as the play and rewind controls look very similar? I beleive the Tandbergs were very good and reliable so wouldn't be surprised if B&O used their transports - but of course I could be totally wrong - interesting to know.
They are not.They were competitors up to the point where Tandberg started producing decks with electronic control, digital ICs, relays and solenoids, and B&O backed out.
Thanks Dillen - that had been bugging me for ages as I always thought they were as the control looked so similar.
