Hi all,
in my quest to find an alternative solution for BMLink after switching to MacOS Catalina (which doesn't have iTunes anymore), I stumbled across shairplay (and similar streaming solution for the raspberry PI). I have shairplay running on a Pi here and when connecting directly to B&O Speakers music comes out fine. But I'd like to have that music on Masterlink so I can select it from any link room.
I have a BV10-32 which seems to have 2 analog audio inputs (one for AV3 - VGA input) and one as AV5 for video camera connected to the set. I activated both, added appropriate sources to my BEO4 and the TV set switches properly to the selected input. Only problem: all stays silent. No audio coming through.
So here are my questions:
(1) Is the BV10 only playing an audio source at AV3/5 if there's a corresponding video input?
(2) Has anyone successfully hooked up an additional audio source to the BV10? If so, please would you mind sharing your wisdom here?
regards
Torsten
