So I scored a couple of RL7000 but didn't get the stands. Does anyone know what type of stand to look for? Is it the same type of stand used for other RL speakers?
The RL7000 stands are Type 6035.I seem to remember they are unique for RL7000.Same goes for the ceiling bracket Type 6023.
Super!
So the RL 7000 stand is differend from the stand to the RL 140 or the RL 60? Just to be sure of where to find something that actually will fit.
Jagarbiffen: Super! So the RL 7000 stand is differend from the stand to the RL 140 or the RL 60?
Yes, they are different.
I own the redline 7000 stands.
Here are some pictures:
Jagarbiffen: Super! So the RL 7000 stand is differend from the stand to the RL 140 or the RL 60? Just to be sure of where to find something that actually will fit.
I am sure that the RL140 stands will fit the RL7000 they just look a bit old fashioned and will probably be rusty by now!
Regards Graham
