NL/ML Delay Box Issues
This post has 1 Reply | 0 Followers
kimhav
Malmo, Sweden
Posts 314
kimhav Posted: Wed, Nov 10 2021 7:37 PM
A year ago I got hold of a NL/ML Delay Box which I managed to get re-flashed with SW H8 101a to get it to work from ML to NL (ref. to this thread). The Delay Box has been working fine, up until couple of weeks ago, when I discovered that when I was in link rooms were I have BL3500/BL4000 I noticed that when pressing TV the speakers is triggered and the BL3500 shows TV in the display and then goes into stand-by. So replaced the original Delay Box with another and same issue.
Are there any settings in the BV10 which could be the cause of this issue which I might for some reason enabled/disabled (no that I can think of something) some kind of feature that cause this behaviour?
Nothing has been changed or altered in any way in the ML-network, so currently don't know what to look for to figure out why I have this issues. So open for suggestions.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Wed, Nov 10 2021 8:02 PM
Well, replaced the ML-cable from the incoming connection from the BV10 with a new fresh cable and now it works again. But, still not sure whether it was a cable issue or if it's something else. So going to check the cables and ports during the weekend to see if it's something else.
Page 1 of 1 (2 items) | RSS
