Beovision 12-65
This post has 3 Replies | 0 Followers
jacob117
Posts 4
jacob117 Posted: Sun, Feb 23 2020 5:37 AM
I am currently about to buy a beovision 12-65 NG but from the serial number and the tables I found in here it seems to be from around 2012 which cant be right for a NG with BS4.
The serial number is 23635068, anyone can help me if this is actually a new generation ?
Btw it is also topasgrey which also suggest to me that it is NG
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Sun, Feb 23 2020 6:44 AM
jacob117:
In 2012 the NL based OS was launched in the BV11/Beoplay V1 and the BS4-BV12, so guess this is correct. If you want to be sure just ask for a picture of the menu of the TV or the sticker on the BS4.
Robert
Holland
Posts 204
Robert replied on Mon, Feb 24 2020 12:55 PM
Correct me if I am wrong:
BV12 NG: NG (new generation) is mainly the BeoSystem 4 that was introduced. And the panel rear that fits to a motor stand.
BV12 not NG was a set with BeoSystem 3.
BeoVision 12-65 MK II panel:
Type 7958, 7964, 7967, 7977 - 7978 (See sticker at the rear on panel BV12)
Mk1 are: BV12 Panel Type 7953 - 7957
Regards, Robert
moxxey
South West, UK
Posts 5,359
moxxey replied on Tue, Feb 25 2020 12:00 PM
jacob117:
That's definitely right. My BS3 model was from 2010 and was not far behind the NG. It's surprisingly old now!
Page 1 of 1 (4 items) | RSS
