Hello there fellow collectors,
I have a question, I just treated myself to a Beomaster 5500, the CD player with the Master-controller and the antenna.
This is my question, the CD player works but skips really badly but you can hear the music and the sound is blaring and you cant lower it for some reason.
Now I go back to use the radio and I notice that the volume can not be lowered and on front panel there is a LOCKED suddenly that I have no idea how that showed up, the weird thing is that i can not adjust the volume since I noticed the LOCKED on the front panel.
Does anyone have any suggestion on what to do? Does anyone know if a 1700 turntable is compatible with this setup?
Many thanks
Mike
