I have cleaned it all out -- I replace the controls and nothing works. Is there some secret to getting the controls to mate up with the contacts???
I would also like to replace the capacitors -- which ones and where can I order them
Thanks very much
*** McDonald
rjm5@sbcglobal.net
Capcitor kits are readily available - from me.So are potentiometer repair kits and lamp kits.The latter two come with detailed (dis-)assembly instructions (photos and english text).Email or PM me.
Hi Martin
What is the price for the volume control lamps kit? My 1900 has the lamp bad for the increase side of the volume control.
Craig
Craig,PM or email me.
my email is nottingc@gmail.com if you could email me
Email sent.
Hi Martin!
I'm right now in process of restoring a Beomaster 1900 can you please help me with a capacitor repair kit(the polyester caps also shows signs of damage, like cracks or even chips falling apart) I'm from Romania, so please have this in mind to estimate the postage costs.Thank you.
Ovi
You have email.
