Hi all,
I am a dealer and we are about to fit a BV7 55" 3D variant for a customer.
They have a number of Region 1 DVDs and Blu Rays and are wondering if they will be able to play these through their new TV, as well as tke UK variants.
Has anyone had experience of using non-European DVD/Blu Ray discs in the latest BeoVision 7?
Thanks,
I am not sure but I would believe that the unit is region code protected and if it is not removed it will only play region free and discs made for the region in which they are purchased.
There are only three different bluray regions and from what I have read I understand that most discs are actually region free. According to wikipedia:
" Some current estimates suggest 70% of available Blu-ray Discs from the major studios are region-code-free and can therefore be played on any Blu-ray Disc player, in any region.
Movie studios have different region coding policies. Among major U.S. studios, Paramount Pictures and Universal Studios have released all of their titles region-free.
Sony Pictures and Warner Bros. have released most of their titles region-free. Lions Gate Entertainment and Walt Disney Pictures have released a mix of region-free and region-coded titles. 20th Century Fox and MGM have released most of their titles region-coded".
Perhaps it is also possible to unlock the region fix on the player but I have no idea how to do so on the new blu-ray units.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I am in the UK,and have a BV7-55 3D with an integrated Blu-Ray player.
I was advised by my dealer that it was locked to Region 2/B for DVD/Blu-Ray playback.
Whilst it is true that more,and more,Blu-Ray discs are being issued 'Region Free',there are instances where a 'locked' Blu-Ray,or DVD,will be issued in the USA long before a European release,and so it is an advantage to have a player for Region 1/A discs.
I would suggest that you contact B & O to ascertain whether or not their integrated player can be unlocked.
Although the integrated player is excellent,I personally prefer to use a hardware modified multi region Oppo BDP-95EU Blu-Ray player as it provides much greater flexibility in set-up,and the firmware can be easily upgraded by the user.
A multi region Oppo BDP-93EU would be cheaper,than a 95,at £599.
Is it not possible to have B&O "unlock" the integrated blu-ray so it can play all regions?
MartinW: Although the integrated player is excellent,I personally prefer to use a hardware modified multi region Oppo BDP-95EU Blu-Ray player as it provides much greater flexibility in set-up,and the firmware can be easily upgraded by the user. Hi Terry, I have the Oppo and bought an online hardware kit but have never been able to get it to work - did you fit the kit yourself?
Hi Terry,
Hi Martin,
I bought the 95 as soon as it was introduced into the UK,and I had the hardware kit fitted by the dealer prior to delivery.
From memory,at that time there were different boards available from 2 manufacturers,but one of the boards was proving to be problematic.
I have never had a problem with the hardware kit that was fitted by the dealer who advised me that it was easy to fit if I wanted to install it myself
It might be worth you getting the dealer from whom you bought the kit to have a look at your player.
In what way is your kit not working?
Raeuber:BTW: The firmware of the integrated bluray player CAN easily be upgrated by the user!
Are you sure?
The only downloadable firmware I can see on B & O's website is for the integrated tuner module.
When the service engineer did a multiple firmware upgrade on my BV7-55 he advised me that the updates were provided specifically to service personnel,and the updates were made via the TV's Service Menu.
TerryM:Are you sure? The only downloadable firmware I can see on B & O's website is for the integrated tuner module. When the service engineer did a multiple firmware upgrade on my BV7-55 he advised me that the updates were provided specifically to service personnel,and the updates were made via the TV's Service Menu.
Many thanks for all your input, this is hugely appreciated and very helpful.
In particular the DVD being able to be region free is a huge sigh of relief for us (and the customer!)
Also interesting to find that Blu Ray discs are often region free. Surely 'region specific' discs are a thing of the past with Internet Shopping so widely available???
Once again, many thanks for all your help.
Raeuber: Change DVD/BR region code by user easyly....? Entschuldigung, das ich den "alten Thread" wieder aktiviere. Yes, I'm sure. Although you can't download the update files from B&O website, you have to connect the BV 7 to the internet via LAN cable. Then with no DVD/Bluray inside press MENU and 8. There you will find the option for updating the bluray player. Regards Räuber
Yes, I'm sure.
Regards
Räuber
Hallo Räuber,
Ich bin jetzt nach fast 8 Jahren vor die Herausforderung gestellt den Regioncode des internen DVD Laufwerk eines BV7 zu andern oder zu entfernen.
Mein BV7 hat leider keinen LAN Anschluß um eine Firmware downzuloaden!
Wie kann man den Region code auslesen, und evtl ändern?
Beste Grüße
wilfried
Hallo Wilfried,
Bist du nun auch sicher, daß kein RJ45/LAN-Anschluß da ist?
Sollte eigentlich, wenn es ein 7-55 MK2 ist!
P.S. Räuber ist seit Jahren nicht mehr auf dem Forum tätig gewesen.
Hallo MM
nein, ist kein LAN Anschluß dran, ist aber auch "nur" ein 7-32 MK3 ! Region Code für DVD steht auf 2.
Ich hatte gedacht, das es für alle BV7 eine Möglichkeit gibt den Region Code auf "0" zu setzen,
damit auch DVD's aus USA abgespiel werden können (Region Code 1).
Gibt es da ein Möglichkeit, die der Benutzer selbst ausführen kann?
schade das Räuber nicht mehr aktiv ist, hat gute Beiträge in diesem Forum geschrieben
Grüßle aus Heilbronn
Aha - ich dachte an BV7-55 da der genannt ist in dem Titel des Postings.
Da hilft dann nur das Service Tool, das es nur unter Mitwirkung eines B&O-technikers gibt.
Danke MM,
wenn es nicht ohne "vor Ort" Besuch des "freundlichen" B&O Technikers geht, dann
schaue ich mir die USA DVD eben nicht an, der Aufwand wäre zu groß
Es ist ja nicht nur ‘der Besuch’, das ein Problem ist, aber vielmehr die damit verbundenen Kosten.
Wenn es wichtig ist (mit der DVD), wäre es sicher günstiger sich einem Player to besorgen, der die abspielen kann bzw leich ungestellt werden kann.
