Hi
I'd like to eliminate human error when setting up my surround sound and I read in a Bang & Olufsen support document 'sound settings' that I can do this with a calibration microphone which can be purchased from a dealer, but my dealer says he cannot find any mention
Perhaps they no longer exist?
What's your setup? Bv avant can take advantage of a mic and so can bl50's but both mic's are different. You could also use a laptop with a mic and software and set it that way. But we need more info
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Maybe your talking about this?
https://archivedforum2.beoworld.org/forums/t/227.aspx?PageIndex=65
Setup is as follows:
Eclipse 65, two front Beolab 18s, two rear Beolab 6000s, Beolab 2 subwoofer, Beosound 9000
Is there a way to calibrate this system automatically?
Hi thorne,
no there isn't unfortunately. To start of I would highly advise to use either a phone DB app or a db meter and start off by setting them all the the same level at the point of where ever you sit :)
OK, it was worth asking the question
