Hi all,
This is my first post here, and I have a question.
I’ve seen some discussions here about the LDR volume control, but what I didn’t find if there is a good replacement available for the lightbulb and its value in wattage and volt range.
Maybe someone can help me out here.
Cheers and thanks,
Curt.
For the proper replacement Bang & Olufsen bulbs/lamps and belts it is safest and best to contact Dillen here on the forum (Martin). You can also reach him on his Beoparts store. I have bought quite a lot of parts from him and they work great...and you know they are the correct items.
-sonavor
Thanks Sonavor,
I already asked Martin and awaiting reply for this specific one.I already have two kits of him that I used for my 1900 and 2400-2, very very happy that Martin has these available for us all.
Cheers,
( edit ) Double post
Another question, is this bulb voltage regulated or is the brightness regulated trough pulse modulation
