My Beomaster 8000 stopped turning on out of stand-by mode. Got the red stand-by display segment, but the unit has no response from keypad or remote. I checked the fuses and mains supply output, they all look fine. I checked voltage at C35 and see 8.2vdc. This was still the original cap so I replaced it with a new 10uf cap. The old one measured 15.2uf. One strange behavior is that from stand-by, when I unplug the mains, i can hear the relays cycle. I put my DVM on the stand-by switch line that should toggle between 0-5vdc at R50 on board 6 and saw a 12vdc spike when I disconnected the mains power and heard the relays cycle. Is there an existing thread that has a good troubleshooting/repair to address this issue? Thanks
Beomaster 8000 generally;
- Bad capacitors- Cracked solder joints at connectors- Bad connectors- Bad processor board vias- Any combination of the above
Start at the 5V supply to the processor. Is it properly filtered?
Measured almost 8vdc output at 6IC4. Input voltage was in spec at 10.5vdc. I replaced the MC7805 voltage regulator and it’s back up and running. I have read a few comments about the heat generated in this area, the heat sink tucks up inside the housing. Is there a quality difference in voltage regulators such that one would run a bit cooler?
Roger
captroger: Is there a quality difference in voltage regulators such that one would run a bit cooler?
There are no shortcuts in Ohms law.The regulator drops a certain amount of voltage at a certain amount of current.No matter how you do it , be that a resistor or a voltage regulator etc. - the amount of power generated will be the same.A larger cooling fin would bring the temperature down but the total power dissipated would be the same.
