Hi all,
for various reasons (mainly difficulties managing HD sources on the 7-32) I’ve decided it’s time for a new tv, preferably a Beovision. The key features I’m after are native HDMI inputs and ML connectivity. Support for the beoremote one would also be nice but not essential.
I’m struggling a bit with my selection because my wife is adamant that any screen above 32” is vulgar. I’ve tried to change her mind in this but it’s a no go so please bear that in mind with suggestions.
At the moment I’m using a Beovision 7-32 with a Beolab 7.1 and Beolab 6000s. The tv is linked to a masterlink network throughout the house, as well as a BLGW and home automation system. I don’t have a NL/ML converter but I’m not against getting one if the tv doesn’t have ML.
As far as I can see my options are
Beovision 7-32 mk5 - does it have the home control overlay?
beovision 10-32
beoplay v1-32
or as an outside option a beosystem 3 with a modern Sony/Samsung/LG 32” panel
grateful for thoughts on my best option here
Many thanks
Luke
L Spad :I’m struggling a bit with my selection because my wife is adamant that any screen above 32” is vulgar.
I've been there too .
That said, I believe you should compare measures. If you come from a BV7 (which has a very wide bezel), I think you can aim to a modern 40" with thin borders like the Horizon for instance.
- Edit -
BV 7/32 : 88 x 57 cmBV Horizon : 91 x 62 cm
Samsung 40" : 91 x 53 (but they seems difficut to find, replaced by 43")
Thanks for the sympathy/solidarity š
I’ve tried the old thin bezel line but I’d didn’t wash unfortunately - I had a hard time arguing up from a 6-26 to the 7-32!
Good thought though
Get a Beosystem 3 latest version (3D) fully updated and your life is saved. Then you can hook up a BV7-32 MKV (as a screen only) or any other non-B&O screen and/or a projector without losing connectivity. I have done it and i am thrilled.
Dimitris-
Thanks Dimitris, I had thought the BS3 might be the most flexible solution. Out of interest, isn’t it quite complex operating your bv7 as a monitor for the BS3? I’d guess you need to have the BV7 in option 5 and the BS3 in option 1 or 2? Something like “link PC” to turn on the BV then source selection for the BS3?
Considering the dimensions of the BV7. A BV10-40 on a floorstand would also be a nice option.
Beobuddy: Considering the dimensions of the BV7. A BV10-40 on a floorstand would also be a nice option.
I didn't mentioned it because it was more than 10 cm more wide and when it comes to the wife deciding, 10 cm start to be à lot
Get a 7-32 with HDMI inputs......and your wife won’t even notice the change ;-))
L Spad : Thanks Dimitris, I had thought the BS3 might be the most flexible solution. Out of interest, isn’t it quite complex operating your bv7 as a monitor for the BS3? I’d guess you need to have the BV7 in option 5 and the BS3 in option 1 or 2? Something like “link PC” to turn on the BV then source selection for the BS3?
Dimitris has described how he has done it here:
https://archivedforum2.beoworld.org/forums/p/40202/298586.aspx#298586MM
matador43: I didn't mentioned it because it was more than 10 cm more wide and when it comes to the wife deciding, 10 cm start to be à lot
It's a matter of personal opinion, of course. But I don't think a 40" BV has a "vulgar" size.
The smallest centerspeaker underneath the BV7-32, would be a BL7-1 (unless if it's a BL7-4). That has a width of 1 meter. When you compare that with a BV10-40. Both have the same width's. You're only using the rather big surround black border for actual screen and add 10cm to it, indeed. And the amount of space the BV10 takes is the therefore the same.I would argue for a bigger screen. The wifes get's pretty fast used to it. Put an ATV4 at the back and the wife will probably be pleased when she starts binchwatching during this virus-period. It would be a win-win situation.
Very easy. But you have to accept the following,
BSYS3 is in OPTION 1 and BV7-32 in OPTION 2
1) You wake up BV7-32 with different command (i use PC) - on BV7 IR
2)You wake up BSYS 3 with the respective command of the source you need (TV,DTV, VMEM, etc) on an external IR eye
3) You need a cheap IR reduced signal plastic for BEO4 (veeeeeeryyy helpful)
And you are good to go
Beobuddy:I don't think a 40" BV has a "vulgar" size.
Me neither and I agree with you on all you said.
For me and my use, perfect size is 40" (and i'm happy with 26 in bedroom even if 32 would fit well too).But my theory on the limite the lady put is that if your not very strict about it it will usually drift for a lot of reasons to the point of having to cope with a too big TV.For instance when I bought my 40" (two years ago) I almost had to fight with the seller to have that size. He explained me very scientifically the very mathematical and intricate link between the screen size, the viewing distance, the color of neigbourh eyes, the global warming and the next presidency political color. After like 40 minutes (not inches) when i still wanted my 40 (inches not minutes) et dropped the case but take out all the offers and bonuses he gave me should i have bought a bigger screen.
To link back to the OP question, I believe the challenge is more to find a 32" or 40" TV still, if he want new.
Thanks everyone for your thoughts and advice. Personally I’d be more than happy with anything up to 50” for the room in question, but my wife simply will not consider anything over 32” as I’ve previously said. 40” is a no go, I’ve made the same arguments set out here for a BV7-40 but she will not go for it.
it is interesting that in the question I explicitly asked about a number of 32” models, but I’ve not hard a lot of love for any of them - am I to assume that B&O don’t have any 32” models worthy of consideration? Didn’t MM have a Beoplay v1 - is that any good?
so far I’m leaning towards the Beosystem 3 solution, initially with my existing Beovision as a screen, but replacing that with a 3rd party panel in due course. Many thanks for that useful suggestion!
I am a huge fan of BV7 looks. In retrospect i should have bought a BV7-40 back in 2005 but my wife thought at that time the same. Too big for our living room. I have someone who mounts any non-B&O TV in the BV7-32 floor stand, still keeping the motorized function and your BL7-1! But the looks that i have seen from other customers...is just not right...
So i am happy for my BSYS3 addition for now, which vastly improved connectivity (much less cabling, image and sound processing) and made possible to keep Masterlink throughout my house.
Thanks Dimitris - you’ve sold the idea to me. I’m going to get the Beosystem 3. Thanks again for all your help
Hahahaha. I liked the "SOLD" like i am a dealer.
But no, honestly it is worth it. Very important to locate the lastest BSYS3 MKIII version (HDMI ports, 3D function etc) and find someone from B&O to fully software update it as it is not always the case.
Why not keep the 7-32 and update the PUC for the Gefen HDMI expander - that should give you 3 or 4 HDMI inputs - not sure if this works with your BV7-32, but my BC6-26 does. I`d check that. And you will need a Gefen expander - should be available second life.
If you have a BLGW, your BV7 has already got the update for LIGHT and CONTROL commands?
You won`t find Home Control overlay on ML BVs unfortunately, this feature is only available on NL BVs...
If you want HDMI sockets, a "small" screen, ML compatibility get a Beosystem 4 and an NL/ML converter.
If 3 HDMI sockets and ML are enough, get a BV10-32. I have one as a link BV with BL6000, and BL11 connected and I love it..
Good luck
Stefan
L Spad : Didn’t MM have a Beoplay v1 - is that any good?
Sure, I have my V1-32 - and am not willing to give that up....I like it very much.
I did not mention the V1, because it is so different from a BV7.
Personally I can not imagine having aBV7-32 where my V1 is, no way.
But we are all different!
As you mention, you’d have to have a converter as well to integrate it with your ML stuff.
You should also consider that you - apart from the HDMI’s - would gain other things.
Amongst these: easy PUC download and internetradio........which could come handy, since more and more FM radio is disappearing.
Looking forward to hear what you will go for.
If you are serious about getting a 32 inch TV then the Beovision V1-32 is the best option. Unique industrial design that says - you wanted a 32 inch TV and that's it. At that size 4K and display technology does not matter. It will check off all your boxes :)
B&O in my life š:
Just get Bsys3 and 40 inch tv.Tell Yours SWMBO that it was wrong delivery.No return,due to circumstances...peace at home
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Thanks everyone
Basically I’ve narrowed it down to a v1 or a Beosystem 3. I can get the v1 plus a BeoLink nl/ml converter for a similar price to a mk3 Beosystem 3 so the clincher will be whether or not the Beosystem 3 with the latest software (black menus) has the home control screen for my BLGW. Can anyone confirm if this is the case?
okay - thanks everyone for your input. In the end MM and others who advocated the V1 won me over. The main argument that won me over was aligning with the more recent NL technology and the user downloadable PUC etc which makes life a lot simpler.
the forum is such a great resource to help with these decisions so thanks!
