I've got a BeoSound 3 Mk 2 (2723) to repair. It's got some corrosion on the Power Board "Module 2", which is in the base of the device. However the service manual assumes board replacement, so it has only a block diagram of this board. Does anyone have a component level schematic diagram for it?
The board is marked "A13 POWER 4300400094" and AL130-00143-2.
Thank you in advance!
Mark
