BeoVision 4 - 65 inch Plasma
ajaychopra007
Posts 1
ajaychopra007 Posted: Mon, Apr 20 2020 11:12 PM
Hello,
I have a Beovision 4 - 65 inch plasma TV that I bought over 10 years back. It's connected to BeoSystem 3. This morning I noticed that I'm only getting sound from the TV but no picture. I tried turning it on & off and checked all connections but no luck. Did anyone else ever have that issue? Any recommendations / feedback on how to troubleshoot and fix this issue will be much appreciated. Thanks !
Jaffrey2230
Washington DC
Posts 520
One way to check if the fault is with the TV vs the BeoVision is to connect a device using the DVI-D input directly and see if that works. The BV 4 is the only B&O TV I have ever owned and it was a rock solid and built like a tank. I had it for around 8-9 years. The longest I have ever owned a TV 🙂. Hopefully it isn’t the main logic board. These were Panasonic panels and the only reason I have heard they failed was if the cooling fans got bad. They generated a lot of heat - I remember, I could feel it from the front...
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Page 1 of 1 (2 items) | RSS
