Dear All,
I'm pondering the purchase of an ML/NL converter, there are a few available second hand.
Are there any different versions of the product I should consider?
Thanks in advance for any help.
Kind regards
Julian
JulianJ:Dear All, I'm pondering the purchase of an ML/NL converter, there are a few available second hand. Are there any different versions of the product I should consider? Thanks in advance for any help. Kind regards Julian
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
