Hello,
One of my Beolab 3 speakers recently stopped working. The light no longer comes on, and no sound comes out. The other speaker works just fine. I switched the power cables to check if it was that - it didn't work with the other speaker's cable either (and the other speaker worked just fine after switching cables). What should I do?
After reading other posts - I see it could be a blown fuse. I do not have the tools nor the capability to diagnose or fix said problem. Any other suggestions? I'm not sure what to do.
Thanks,
Simon
I think you need to take it to a repair shop.
If you have a Gold membership you can get the service manual, but its quite a lot of work (lots of screws) to get into these speakers.
Since you (as me) seem to have limited knowledge regarding this type of tech, I would not advise you to dismantle the BL3.
/C
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I wouldn't suggest opening it yourself, I have opened one before and there are a lot of screws but the fuse isn't the pull out and replace type. If you have no knowledge of electronics or soldering then you won't have a clue what you are looking at. The manual also mentions using an anti-static wrist band to protect the electronics.
if you do not have knowledge of electronics, better to take it to expert.
it says here how to disassembly https://hi-tech-remont.com/bang-olufsen-beolab-3-razborka-i-remont/PS
1. Replacing the fuse did not help
2. Power supply burned out
