Apple TV Beo 4 BR1 question
Razlaw
Posts 4,345
Razlaw Posted: Sat, Apr 25 2020 12:13 AM
I have an Apple TV connected to a BV7 and another Apple TV connected to a BV10. I control the BV7 Apple TV through the puc with a Beoremote 1. The one connected to the BV10 is controlled through the puc but with a Beo 4. The one connected to the BV7 is perfectly controllable with the puc. The one connected to the 10 is also controllable through the the puc, but the response has been very sluggish. There is a delay between pushing a button and when the Apple TV responds in some instances. Today I tried the Beoremote 1 with the BV10. The Apple TV works perfectly, no delay. I think I will order another BR1. But, I am curious...why would switching remotes affect the speed with which the puc controls the Apple TV? I also have a old Apple TV connected to a 20 year old 32 inch Avant. Using a Beo 4 to control it through the puc works quickly and smoothly also.
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Razlaw,
which gen of the Beo4 (with or without the navi button) are you using on the BV10?
Razlaw
Posts 4,345
Razlaw replied on Sat, Apr 25 2020 12:39 PM
Without.
Razlaw
Posts 4,345
Razlaw replied on Sat, Apr 25 2020 12:55 PM
I tried a Beo 4 with the navigation button. It worked fine so it is the non navigation Beo 4. Surprising to me that that would make such a difference in how the puc responds.
Millemissen
Flensborg, Denmark
Posts 14,680
Ha, that is exactly what I supposed!
I use only Beo4’s with navi in my setup.
Page 1 of 1 (5 items) | RSS
