Does anyone know where i can get a new or used working power supply board for a beolab 3?
many thanks
you cannot buy that because powerboard is not sparepart only complete electronic mk2
As someone else has replied if the Beolab 3 is a mk1 model there are no new parts available. The brilliant B&O repair guy Jim here in Scotland,managed to repair my mk1 power supply failure but said it was quite an operation and learning curve! Apparently mk2 can have whole board(?) replaced and that part was still available a wee while back. You will need to look at the serial number and work out where you stand..I was lucky and the cost of £250 was very bearable at that point.
Unfortunately repairing a MK1 if you do not have a geek who is able to fix and you need a replacement of the electronic does not make any sense these days. Th replacement unit plus labour was close to 700 Euro, so to buy a used pair is probably the better choice
