Beogram 3300 CD lid problem
darcher121
Posts 3
darcher121 Posted: Fri, May 8 2020 1:44 PM
The lid only raises when I push the button if I help it with my finger, motor whirrs but it doesn't open on it's own. It closes fine.
Would this be the lid opening drive belt slipping?
If so, where can I buy the right belt (part number?) and how should I open the CD to replace it. I am happy with this type of repair as I repair vintage cameras as a hobby but would appreciate advice before I start,
Thanks!
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Most of the time, the teeth of the gear has (partly) broken. I can provide that part.
It's made of nylon the very close to the original.
If you need that part, send a pm.
Page 1 of 1 (2 items) | RSS
