I have a question in regards to remote controls from B&O, as I've been looking fo an article or place to see the individual models and which systems/models of A/V they are compliant with. I found one great article for BEO link 5000 and 7000. But where do I find information on other models. like it seems like there is quite a few BEO4 models as an example, so what is the difference between each.
I guess the is an article and I just didn't find it, so if you know of it please share the link.
Thank you in advance
Kim
You can find a wealth of information here:
https://beocentral.com/beolink-terminals
Also, you can find much information on this BeoWorld site under the Products descriptions.
Thanks a lot that indeed answer a number of my questions.
