Hi can I connect a B&O core to a 3500 speaker directly to convert it to a apart speaker?
There you go
https://soundsheavenly.com/airport-express/155-ipodtvairport-express-to-beolab-3500-mk2-cable.html
Hi
Many thanks to both contributors.
It saves a fortune over buying another Beosound 35.....good as it is.
Are second hand cores available? eBay doesn't seem to offer any / many which seems strange
Thank you Andrew
If you don’t already have the Core, a ssecond hand Essence MK2 will do the job - for less money and easier to find.
Thanks I'll look out for one
Sometimes Cores show up on eBay but they sell pretty quickly from what I can tell and are priced close to what you would pay for one that is new. Having used one for a while, I can see why. They are a high quality and reasonably priced way to turn any powered B&O speaker into a flexible and modern multi-room system. To me it made a big difference to my BL11/BL 6000 combo.
I also have the Essence Remote with it, but don't use it since it's easier to just use the app.
If the Essence is similar to the Core and cheaper, then that would be a good option as well.
B&O in my life 😊:
