Configuration tool for Beo 5/BV11?
This post has 6 Replies | 2 Followers
danperfect
Posts 6
danperfect Posted: Mon, Jan 21 2013 1:50 PM
Hi all
What version of the configuration tool do I need to be able to include the BV11 in my setup? I only can find 4.11, and that only has up to the BV10..
Any help appreciated!
Vienna
make an educated guess
Posts 1,090
Vienna replied on Mon, Jan 21 2013 1:57 PM
danperfect:
6.00
danperfect
Posts 6
Will that not cause me problems uploading to a Beo5? Can I do this using Vista, running Parallels on a Mac?
Vienna
Posts 1,090
Vienna replied on Mon, Jan 21 2013 3:33 PM
danperfect:
Should work if firmware on Beo5 is 1.45 (or later) and Windows is a 32-bit version.
danperfect:
I don't know, not using my "fruit devices" for that ...
berlin2010
Posts 92
berlin2010 replied on Thu, Jan 31 2013 12:48 PM
Also wondering which version is needed - I have 6.02 and whilst that has the BeoPlay V1 it still does not have BV11 - anyone know for certain which version?
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, Jan 31 2013 1:37 PM
In CT 6.00.02 under Recent Changes you will find "Improved BV11 support".
V1 is in the Beoplay section, BV11 in Beovision section.
Stefan
berlin2010
Posts 92
Thanks, figured out not to tick the "work offline" option when starting. It then downloads all the updates.
Page 1 of 1 (7 items) | RSS
