Hi Beoworld
I have a Beocenter 9000 in which I have just changed the mute relay in hopes of it being the source of my problem with the speaker in the right channel in speaker 1, but without luck. I have tested it today and it actually seems like the right channel in speaker 2 is also a little lower than left. The left channel works perfectly in both 1 & 2 but the right channel in 1 has no output.
I do also have a problem with the CD player, it doesn’t read the CD’s anymore or at least it tries to but then turns off.
Hope you have some suggestions on what to try next.
