Which B&O App do I need from the App Store?
LR2015
Posts 81
LR2015 Posted: Sun, Dec 9 2018 1:28 PM
I notice there's a couple of B&O Apps but which would be best for me?
I only have a BV-11 with a pair of BL9's so no room integration, yet. I want it mainly for inputting text, for example - when I was just setting up Apple TV it took ages to input all the text like email address and passwords etc.
Millemissen
Flensborg, Denmark
Posts 14,680
If you mean settings in the ATV, you won’t need a B&O app.
Apple has an app called Remote for this.
If you still have access to the ols Beoremote app, you could use that for some controls of the BV11.
Otherweise the Bang & Olufsen app is the app nowadays - it basicly includes the functions of the Beoremote app.
LR2015
Posts 81
LR2015 replied on Sun, Dec 9 2018 2:52 PM
Brill - thank you.
re the old app - I have got it on my iphone but it always seems to be 'searching' for the tv. That's what got me thinking about looking to see if there is a newer app. I'll check the App Store out. Cheers
Thomaslewis
Posts 1
Hello! If you want to download free and secure premium apps for your device, you can refer here https://apkmouse.com
Page 1 of 1 (4 items) | RSS
