Beolit 505 volume problem
Pmajander
Posts 1
Silver Member
Pmajander Posted: Sat, Jul 24 2021 1:04 PM
Hello,
I bought a beolit 505 portable radio a good while ago. I tried it then and found out that the volume increased by itself to the max. So, I put the radio into shelf to wait better times.
Now, I thought to test it again. I switched it on and now it comes to max volume no matter where the slider is.
I tried to clean the volume potentiometer with spray, but no affect.
Any idea where the problem might lie?
Regards,
Pekka
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Jul 24 2021 1:17 PM
Bad volume potentiometer or lead(s) broken off.
Check the potentiometer with an ohmmeter.
Page 1 of 1 (2 items) | RSS
