Beosound Core and Chromecast
troyh
Posts 8
troyh Posted: Sat, May 30 2020 1:02 AM
I have a Beosound Core, which has “Chromecast built-in” but all my Chromecast-enabled apps do not see it on the network as a Chromecast device. It can be seen as an AirPlay device but not Chromecast. I also have an A9 and 2 Beosound Stages and they are visible as Chromecast devices. Why doesn’t the Core show up? Does anyone use it as a Chromecast device?
Thanks!
Razlaw
Posts 4,345
Razlaw replied on Sat, May 30 2020 1:43 AM
I do not use Chromecast with my Core as I prefer the B and O app. However, I have tried it and it does work. When setting up the Core in the B and O app I believe there is an option to enable Chromecast. Might be something to check, see if it shows as enabled in the B and O app.
troyh
Posts 8
troyh replied on Sat, May 30 2020 1:59 AM
It is enabled in the B&O app and it shows up in the Google Home app as a Chromecast device. It just doesn’t appear in Tidal or Qobuz, for example. I can use it for Spotify because it uses Spotify Connect. You see it listed in Chromecast apps as Chromecast or as Airplay or both?
Razlaw
Posts 4,345
Razlaw replied on Sat, May 30 2020 3:41 AM
In Deezer it is visible and I can connect both with Airplay and Chromecast.
troyh
Posts 8
troyh replied on Mon, Jun 1 2020 5:25 AM
I fixed it by resetting the Core to factory defaults and starting over. Chromecast shows up in APs now and works great now. I still don’t know why it stopped working.
mtlhd
Sweden
Posts 9
mtlhd replied on Sat, Jun 20 2020 10:09 AM
I have the same issue. It shows for a while, and then disappears. I found a workaround by creating a one speaker group for the Core Chromecast from within the Google Home app. So now I have a group called Bedroom and the BS Core not grouped is called Bedroom Core. The group is always selectable from within my apps.
Page 1 of 1 (6 items) | RSS
