Hi
Airplay on my Beolit is just not reliable and I am looking for a rechargeable Bluetooth receiver to improve connnectivity with my iphone I want to use it in the garden so it can’t be plugged into power
Can anyone recommend one that’s not too expensive?
Sounds good. Is there a combo available or do I buy the receiver and battery pack separately. Any suggestions would be welcome
thanks
I'm not familiar with the Beolit 12, but on my Beolit 15 I use the USB port on it to power a small WiFi streamer that's also plugged into the line input. If you can find a BT dongle that can be driven by USB levels of power that would be an option. I have a hard time imagining that a BT dongle really needs a much power.
Jeff
Hi Leosgonewild
Thanks for the heads up. So do you have a Bluetooth receiver and battery pack recommendations?
leosgonewild:Powering a device via the usb on the 12 and feeding the six input with said device usually results in noise.
Interesting, seems to work without noise on my 15. Go figure.
