BS 9000 buttons gone crazy
This post has 6 Replies | 0 Followers
BenSA
Durban, South Africa
Posts 1,404
BenSA Posted: Fri, Jun 26 2020 8:25 PM
My 9000 works flawlessly via remote, problem is all the buttons have gone faulty. Press radio you get aux...press balance get volume etc. also the door button isn’t working.
Any ideas…
BenSA
Posts 1,404
I've narrowed the fault down. As long as the ribbon cable to the control panel is disconnected the door button works as well as theCD buttons. Soon as I connect the cable back those buttons stop working and of course the control panel still doesn't work. I'm presuming it must be that small board that's faulty?
matador43
Posts 1,373
matador43 replied on Sat, Jun 27 2020 2:37 PM
Hi BenSA,
I don't know but doesnt worth a try to open the control panel and give it a good clean before anything else.
I mean it may be a stuck key on the main panel (seen on BS2500 and alike and some remotes).
BenSA
Posts 1,404
BenSA replied on Sat, Jun 27 2020 4:50 PM
Thanks matador but you can't open the control panel. No screws. Also if the panel is out and I connect the ribbon cable the cd buttons..on off switch and door switch don't work. If I disconnect the cable the cd...on off and door switch work. I can only think its the pcb board
matador43
Posts 1,373
matador43 replied on Sat, Jun 27 2020 5:24 PM
Oh, Sorry to hear that. Good luck then.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sun, Jun 28 2020 11:41 AM
It happens, not often, that the small pcb for the keyboard fails. I've seen them with a small pimple on top on one of the ic's.
If you rotate your keyboard and your display doesn't turn, then you can be pretty sure that the pcb needs to be replaced (or new ic's soldered)
BenSA
Posts 1,404
BenSA replied on Sun, Jun 28 2020 2:59 PM
Thanks Beobuddy, at least I know now that it does happen that the board goes faulty.
Will source a replacement board. Hopefully solves the problem!
Page 1 of 1 (7 items) | RSS
