Beosound 3200
umbers
Posts 4
umbers Posted: Sun, Jun 28 2020 9:37 AM
Hello Beoworld,
I'm new to this so I hope I'm posting this question in the right place.  I've owned B&O since the 1970s.  I bought my Beosound 3200 new (ex display) from a B&O dealer in 2011.  It's not used daily and I've had no problems but yesterday suddenly stopped playing CDs.    When I press play, the CD starts revolving as normal, seems to get to speed and then stops.  I've tried various CDs but it's happening on all of them.  I have a local B&O dealer who can look at it but I wondered if this is a fault that might be something I can attend to?  Thanks for any advice you can offer.  William
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sun, Jun 28 2020 11:19 AM
Nothing you can do other than cleaning the cd's.
Sounds some trouble with your CD drive. That takes a lot of screwing around in the BS3200, aside from the fact that you don't have the replacement drive for it, if it needs to be replaced.
umbers
Posts 4
umbers replied on Sun, Jun 28 2020 12:04 PM
Thanks for this.  I don't think it's the CDs because they were clean and, in some cases, mint.  I managed to get it to play this morning but, after a couple of tracks, it ground to a halt.  It sounds like it is, as you say, something more serious than I can deal with. Thanks again.
Champbeo
Posts 43
Champbeo replied on Sun, Jun 28 2020 1:34 PM
Hi
Make sure to clean the CD laser also.
umbers
Posts 4
umbers replied on Sun, Jun 28 2020 1:48 PM
Thanks for this.  I've cleaned the laser - at least from the front (without dismantling anything).  I can get it to play but it now cut outs intermittently and then just stops ...
OldJack
Split
Posts 371
OldJack replied on Sun, Jun 28 2020 4:51 PM
Beobuddy:
There are some replacements on ebay (I have nothing to do with sales)
https://www.ebay.co.uk/itm/B-O-Beosound-3200-Laser-Lasereinheit-Neu/143567878073?hash=item216d4ff7b9:g:fr0AAOSw9bFcd4U6
https://www.ebay.com/itm/Laser-Unit-Bang-Olufsen-Beosound-Century-Beocenter-2500-2300-3000-3200-2/293627639222?hash=item445d9235b6:g:WGQAAOSwaTJe7zWK
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
umbers
Posts 4
umbers replied on Sun, Jun 28 2020 5:04 PM
Thanks OldJack and BeoBuddy.  I think you are right.  I'll see what my local B&O dealer says ... and what they'll charge to repair!  Best, W
Page 1 of 1 (7 items) | RSS
