Is it possible to hook up a non Bang and Olufsen TV to play through the Moment?
The Moment has 1 x Line-in (RCA) which you should be able to use.
Surt:Is it possible to hook up a non Bang and Olufsen TV to play through the Moment?
But beside the line-in delay I would still argue Yes it's possible if you just want to feed the audio into the Moment and ML/NL network.
