I posted a question ages back and on recommendation (or really a reminder that it exists) I got a BeoTime. It really is a great little alarm clock, different to the usual plastic stuff and a very B&O nicely made design.
The only reservation I have is that it seems amazingly sensitive to movement. I have it on a shelf next to my bed and I get the idea that it's supposed to light up when I pick it up but the movement sensor seems overly sensitive to the almost silly extent. If I wake up and want to know the time, I can gently tap on the shelf and this is enough to trigger the light.
This is admittedly quite handy sometimes as I can't necessarily see where it is if it's dark and I'm groggy but it turns on even if I place anything on the shelf above or place a heavy object down next to my bed. Is this a normal thing or is there a sensor that maybe needs cleaning inside? I only wonder as it probably knocks a good 20% off the battery life as it is.
Hi Calvin,
My Beotime is the same - last night I woke up and sneezed at exactly 1:33am (I know this because the movement was sufficient to trigger the light on the Beotime on the cabinet by the bed!)
I think the short answer is "TADTS" (they all do that sir)
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Calvin:I posted a question ages back and on recommendation (or really a reminder that it exists) I got a BeoTime. It really is a great little alarm clock, different to the usual plastic stuff and a very B&O nicely made design. The only reservation I have is that it seems amazingly sensitive to movement. I have it on a shelf next to my bed and I get the idea that it's supposed to light up when I pick it up but the movement sensor seems overly sensitive to the almost silly extent. If I wake up and want to know the time, I can gently tap on the shelf and this is enough to trigger the light. This is admittedly quite handy sometimes as I can't necessarily see where it is if it's dark and I'm groggy but it turns on even if I place anything on the shelf above or place a heavy object down next to my bed. Is this a normal thing or is there a sensor that maybe needs cleaning inside? I only wonder as it probably knocks a good 20% off the battery life as it is.
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Pretty much the same here with my two Beotimes. I have noticed that the sensitivity seems variable at times, perhaps it's a function of battery level, maybe the motion sensor can get a tad sticky. The one on my wife's side of the bed, right now anyway, is far more sensitive then the one on my side. I have to tap mine, but at times if I walk into the room hers will light up (upstairs wooden floor, creaks nicely too!). Personally, I'd prefer it more rather than less sensitive. I went through a period on mine where you had to bang it pretty hard to get it to light up, a simple tap wouldn't do. I changed batteries and whacked it against my hand a few times, seemed to revert to being pretty sensitive after that. I have no idea if it was the batteries or the sensor though.
Jeff
Never experienced over sensitive BeoTime. However it did run the battery down by resting it against the bedside table at an angle. Won't do that again.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Just got mine working again - the batteries had fused inside it and the battery cover wouldn't unscrew - it broke the tool!! Had to screw 2 self tappers into the cover and use some surgical clamps to open it up! I think it is a wonderful piece - real whimsy. Rubbish clock or remote though!!
Peter
I've managed to break a few of the little tools when trying to remove the battery covers that have been tightened to an inch of their life.
Once its off, I found it more practical to put the cover back on inside out. There is a brace in the middle of the plastic cover on what would normally be inside. It makes it much easier to remove as you can just unscrew it with your fingers.
Opman
Same problem, to sensitive; unusable into the bedroom.
Has someone tried to disconnect (if possible) the motion sensor?
altist:Can’t you turn the sensor bit off somewhere in the menu? Sure I’ve done so on mine as it was super sensitive and ate batteries accordingly.
You are right with "touch enable off". But disable motion AND touch. It could be fine that touch is already working...
