Beocord 8004 tape select problems
CJ
Aa - DK
Posts 8
CJ Posted: Mon, Aug 3 2020 6:06 PM
Recently got a hold on a serviced Beocord 8004, but I can't help but wonder if it's normal for the metal light to come on whenever I insert a Type 2 tape?
Also when recording onto type 2 and 4 cassettes I lose some treble compared to recording on type 1 cassettes.
Metal is not so bad until I enable Dolby C which is no problem when recording on type 1 but falls completely flat when used on type 4.
And whenever I record on type 2 cassettes it's like it uses Metal bias so the treble aren't as clear as I know a TDK SA-X tape normally to be.
So I was wondering if anyone have experienced the same and what to do if it's a malfunction?
CJ
Aa - DK
Posts 8
CJ replied on Sat, Aug 8 2020 1:06 PM
To anyone who happens upon this thread with the same problems, my fix was that some of the wires on the tape selector switches had broken off so the bias and tape selection was all wrong except on type 1 cassettes.
CJ
Aa - DK
Posts 8
CJ
Aa - DK
Posts 8
Page 1 of 1 (4 items) | RSS
