Hello everyone.
This is my first post as I have just joined.
Ive have had my Beolab 3000 system for years with the beolab 2500 mkii speakers attached to the system. I then bought a pair of 6000 speakers and the beolab active subwoofer..
Ive just bought an RX2 to add to this for my old vinyl records.
One of my 2500 speakers does not play. Do I need to add a splitter of some sort to the back of the beolab 3000 to activate the speaker thats not working?
Can the beogram be linked to the beolab?
Jonserinio:Hello everyone. This is my first post as I have just joined. Ive have had my Beolab 3000 system for years with the beolab 2500 mkii speakers attached to the system. I then bought a pair of 6000 speakers and the beolab active subwoofer.. Ive just bought an RX2 to add to this for my old vinyl records. One of my 2500 speakers does not play. Do I need to add a splitter of some sort to the back of the beolab 3000 to activate the speaker thats not working? Can the beogram be linked to the beolab? Thanks
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Thanks for your reply.
I have the beosound 3000 and not beolab.
I unplugged one of the plugs to the 2500 speakers and plugged it into the 6000 speaker and from there to the subwoofer. Ive been trying to fathom it out and found that some have said to plug in the subwoofer to the beosound and from the subwoofer to all the other speakers. Is that right?
I have also read that there is a left and right switch on these. Do I simply switch to whatever side i want the sound to come from?
I currently have a TV in the middle, Beosound underneath the tv with beolab 2500 either side of that, beolab 6000 either side of them and the subwoofer on the left hand side of the 6000 speaker as I look at the TV.
Hope this clarifies a bit.
Can I make these old speakers wireless by any chance? All the cables look a bit ugly to me.
Thanks again
thank you
Hi.
I have bought a pre amp. I connected the rand L speaker from the RX2 to the preamp and from there to the aux equipment on my beosound 3000. With one of the speaker ports ive a lead going to the boe lab 2 sub woofer. From there to one beolab 6000 speaker and from there to the other 6000 speaker. They dont work with the left or right speaker switch though and only work when the switch is set to the middle.
Ive not got enough leads yet for the other speakers but ive got leads on order.
Thanks for your help
So your connection is:
1. PowerLink out from BS 3000 to BeoLab 2
2. PowerLink out from BL 2 to Beolab speaker 1
3. PowerLink from BL speaker 1 to speaker 2.
4. You have set speaker 1 and 2 as L/R accordingly.
you should check/ try switching the port on speaker 2 to see if that fixes the problem. I didn’t recall the switches on my BL 6000 now, but I believe, the middle is for right and bottom is line-in. So looks like you are not getting the left signal.
B&O in my life 😊:
Thanks Jaffrey
I will try that thanks
