Beogram 5500 set up questioon
miamimin
Posts 4
miamimin Posted: Sat, Aug 1 2020 5:45 PM
Is there a way to setup a beogram 5500 with the beomaster 7000?
Thank you.
styppen
Slovenia
Posts 86
styppen replied on Sun, Aug 2 2020 10:47 AM
There is, however you will need a phono preamplifier since Beogram 5500 does not have it built in and Beomaster 7000 does not have a phono preamp (it was built in the Beogram 7000).
If you put in a generic phono preamp you wont be able to control Beogram 5500 via Master Control Panel. You might need a preamp with DIN plugs that will also forward the datalink signal that is needed for remote operation of the Beogram 5500. Not sure where to find such a unit. I'll have a look around.
Let me know if you need more info.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
I think Sounds Heavenly can supply a complete kit for this job. Contact them via the advert at the bottom of the page.
Regards Graham
Page 1 of 1 (3 items) | RSS
