Beosound 2
This post has 1 Reply | 0 Followers
gazman
Posts 1
gazman Posted: Wed, Aug 5 2020 6:30 PM
Hello - Beosound 2 - Doors (wings) keep opening and closing - help ?
The Beonic Man
Bristol
Posts 812
I think you mean the BeoCentre 2 gazman. Have you tried cleaning it a little where you can? I had a problem with my BeoSound 9000 and regular dusting and cleaning helped stop a similar issue. Try using isopropyl alcohol or distilled water and an earbud for example to clean around the laser. Go slowly and carefully though. If this is happening without a CD/DVD inside, which the unit is attempting to read but keeps giving up then it may be a hardware issue that would be a more difficult fix. Hopefully not though. Simon.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Page 1 of 1 (2 items) | RSS
