Beomaster 3000 type 2402 light issue.
musicgeorge11
Posts 8
musicgeorge11 Posted: Fri, Aug 7 2020 11:19 PM
Hope all of you are well and safe. What I thought was a simple replacement of light bulbs for my Beomaster 3000 type 2402 turns out a different issue seems present. Replaced them all and none of them works and I'm not getting any volt measurement from the bases, just a slight measurement for the stereo signal. Any ideas what is going on and where to look?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Aug 8 2020 7:46 AM
Is the Beomaster working - apart from the missing lights?
musicgeorge11
Posts 8
Yes, everything is working!
jegy
Posts 6
jegy replied on Sat, Aug 8 2020 3:46 PM
Check for broken wires and their connections related the bulbs sockets Smile
jegy
Posts 6
musicgeorge11
Posts 8
Thanks, will do, I can understand that happening (broken wire) in one or two sockets, but all of them is too much of a coincidence.
musicgeorge11
Posts 8
All wires and sockets good.
musicgeorge11
Posts 8
Mystery continues.
musicgeorge11
Posts 8
Any suggestions are more than welcome.
Page 1 of 1 (9 items) | RSS
