I have my bl18 connected to my eclipse wireless, and I was hoping to get my beosound moment in that system as well.. I know that multiroom is there and it works fine, however I would prefer using wisa.
I guess my question comes down to: I need to play from my moment directly to my eclipse and the beautiful 18 Using wisa - is it possible and how do I make it work ?
as of right now I can only get my moment to connect to 18, but then my tv doesn’t, and the other way around. So I’m using multiroom to my big disappointment.
i really hope for any help. thanks in advance.
You cannot ‘NL-integrate’ a NL audio device with the Eclipse, since it basicly is an audio device itself with a tv (and HDMI..... etc).
That is something you did with the previous gen BV.
But you can ‘NL--connect’ both - meaning you can use the sources of the Moment via the Eclipse (activated there through the BeoRemote/the app).
However, how much need there is for this, is doubtfull?
If you are in for vinyl or cd playback, you could connect that device to the Moment and listen throught the Eclipse, though.
Better WiSA-connect the BL18’s to the Eclipse and keep the Moment in another room (‘connected’ to the Eclipse) with another set of speakers.
Millemissen:You cannot ‘ NL-integrate’ a NL audio device with the Eclipse, since it basicly is an audio device itself with a tv (and HDMI..... etc). That is something you did with the previous gen BV. But you can ‘ NL--connect’ both - meaning you can use the sources of the Moment via the Eclipse (activated there through the BeoRemote/the app). However, how much need there is for this, is doubtfull? If you are in for vinyl or cd playback, you could connect that device to the Moment and listen throught the Eclipse, though. Better WiSA-connect the BL18’s to the Eclipse and keep the Moment in another room (‘connected’ to the Eclipse) with another set of speakers. MM There is a tv - and there is a BV.
Lassebo:So I’m using multiroom to my big disappointment. i really hope for any help. thanks in advance.
Thank you .. but that would be like multiroom right ? Because I have that working now ..
I was hoping to Wisa connect the moment to the tv
Lassebo: Thank you .. but that would be like multiroom right ? Because I have that working now .. I was hoping to Wisa connect the moment to the tv
The very short explanation:
WiSA is a wireless connection from an audio Source (Moment, Eclipse...) and the speakers.
WiSA allows for up to 8 speakers in a multichannel configuration.
You might say, it is a wireless cable - B&O often also use the term WPL (wireless powerlink).
Beolink - in the newest version called NetworkLink/NL - is a way to share sources ( = the music/sound from these) between different B&O audio devices = multiroom.
