I have my 50s connected to a Core by optical. The Core is set to fixed level out as I was told this was the preferred method when I purchased the 50s. The problem this causes is it complicates turning the Core on and adjusting volume. It is always a two step procedure. First option is to turn Core on from app then switch to the 50s in the app to adjust volume. Second option is to turn the Core on with a BR1 then switch menus in the BR1 to BL50 and adjust volume through the ir eye connected to the 50s. I also have an Essence remote that controls the volume through the ir eye.
I was thinking about switching to variable out from the Core and thus I could adjust the volume from the Core menu in the app, or the Core menu in the BR1, or with a Halo. My concern is having both the Core and the BL50 volume controls active. Could that somehow cause a damaging level of volume to the 50s? I could set a low default and low maximum volume for the 50's volume control in the app.
Any thoughts or opinions? Anyone controlling their 50s or 90s volume through the Core menu in the app instead of the 50s/90s internal volume control?
Thanks!
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Seems like a big goof to launch this beautiful but glorified remote control and exclude it from functioning with the company’s two fanciest speakers in the way those speakers’ technical sound guides recommend...
Hopefully a software patch can resolve this...? If B&O is listening...?
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Curly:Seems like a big goof to launch this beautiful but glorified remote control and exclude it from functioning with the company’s two fanciest speakers in the way those speakers’ technical sound guides recommend...Hopefully a software patch can resolve this...? If B&O is listening...?Currently: BeoSound Core, BeoLab 17, BeoLab 18Previously: BeoSound 1 non-GVA
