Beolab 7.1 - no sound - Any ideas ?
This post has 6 Replies | 0 Followers
cooldude
Posts 101
cooldude Posted: Thu, Aug 27 2020 2:31 PM
Hi everyone,
I have a beolab 7.1 that I stored for a few years and want to get going again but has a problem.
I contacted it up to my beosystem 3 as front speaker. It seems to come on (I hear the relay click and see the red light turn green in the back)  but no sound whats so ever come out.
Anyone got any ideas on what to test for or could be wrong ?  It doesn't seem to be the power supply as it I do get the light in the back and I do hear the relay.
Any help would be greatly appreciated !
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Aug 27 2020 6:23 PM
Is there actually something playing on that channel? IE is the bs3 setup correctly?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
cooldude
Posts 101
cooldude replied on Thu, Aug 27 2020 6:30 PM
Oh yes, I had a BL4000 connected to it before.
And I did try a BL2500 speaker of my Ouverture as well, so yes it works.
@mikipedia  :  love the podcast !  Smile
cooldude
Posts 101
cooldude
Posts 101
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Aug 28 2020 12:17 AM
Thanks Big Smile
All i can think of is to check the connections and see what’s set to go where audio wise. Other than that i am running out of ideas that are easy to fix...
OldJack
Split
Posts 371
OldJack replied on Fri, Aug 28 2020 12:43 AM
Try to assign your Beolab 7.1 as center speaker (not front) on Bsys3, and plug it into center speaker input.
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Page 1 of 1 (7 items) | RSS
