Subwoofers with Beolab3
This post has 14 Replies | 3 Followers
Surt
Posts 5
Surt Posted: Sun, Aug 18 2019 3:27 AM
I currently have a BeoLab 11 subwoofer with my BeoLab 3 speakers.  Any advantage to changing to the BeoLab 2?  I am only using the system for music, not with a tv. Thanks
Chris Townsend
Qatar
Posts 3,531
The Beolab 2 is hilarious for action movies, and will quite literally bring your house down. But it’s like a drunken dad at a wedding for music. Again fun, but timing and finesse aren’t really it’s forte.
Manbearpig
Posts 908
Hello, simple answer: no. The Beolab 11 is perfect with 3s. I am actually looking for another one to replace my 2 with. Cheers, Kai
lawrencejmcook
Posts 742
Surt:
Visually, the BL2 and BL3s make a great statement.
The fact that you’re even considering a change from BL11 suggests that you feel there is something missing.
Given the great visual effect and the low price of BL2s now, go ahead. You can start with BL2 in polite “corner” setting, and experiment from there. It will make you smile 😊
Lawrence
oli
Southeast of France
Posts 141
oli replied on Thu, Aug 27 2020 4:19 PM
Chris Townsend:
I totally disagree with that. In my setups/rooms (I insist on that because I think room response is a key factor in any setup, especially for bass), I actually use now a BL2 for Music only (with BL3) in my office, and a BL19 replaced the BL2 in my bedroom for movies (connected to a BV11-55 with a pair of BL8002). Initially I bought the BL19 thinking the same that what you are writing, after reading the forums, so I tried the opposite (BL3+BL19 and BL2/BL8002 on the BV11), after triggering everything in all possible settings, never succeeding to reach out the WOW factor until I reverse both subs.
Ravsted
Denmark
Posts 345
Ravsted replied on Thu, Aug 27 2020 7:47 PM
I bought Cambridge Minx X201.
Compact sub using same principal as BL3. One 6.5" woofer and two slaves.
I went for black. No speaker cover. Paintet the Cambridge text black. Looks great with BL3.
And in contrary to the BL's you can tune volume and frequency as you prefer.
marexy
Posts 710
marexy replied on Fri, Aug 28 2020 8:33 AM
Minx 201 is ok...i have one setup with mirage mm6 and niles 6,5 and it is much better but more expencive. And yes..on all you have options for tune it as you wish.
BeoAnna
Posts 78
BeoAnna replied on Fri, Aug 28 2020 12:57 PM
Chris Townsend:
Hahaha! I am in full agreement with this statement.
The Beolab 2 is house-demolishing awesome for movies, but I wouldn’t use it for music listening; it’s just too much.
I generally prefer to stick with 2.0 setups for music listening though, but I did at one point consider getting the 18’s along with a 19. Still not sure if I’ll eventually commit to that, since I never really managed to resolve my whole internal “18+19 vs 20” conundrum. I do hate how the 20’s now have that illuminated logo though, they were so much better looking with the illuminated ring (ala 9’s).
OldJack
Split
Posts 371
OldJack replied on Fri, Aug 28 2020 2:18 PM
BeoAnna:
Chris Townsend:
Did you try to make some bass adjustments on Bsys3 with your Beolab2 ? I am using it for music and movies,sounds excellent to my ears...
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Jaffrey2230
Washington DC
Posts 520
I have both BL 11 and BL 2 in my set up and there is just no comparison. I have also owned a variety of other subs. The BL 2 is totally in another category when it comes to performance compared to the BL 11. The BL 2 is one of my favorite subs out there from any brand - I even prefer it to the BL 19.
I know some mentioned the Cambridge Audio Minx X201. Interestingly, I have post here somewhere where I replaced my BL 11 at one point with a single Minx 201 and once I had adjusted the settings the tiny Minx X201 outperformed the BL 11. If you get two Minx X201s, remove the grills and connect them together (the Minx has an audio out connection to link multiple subs) you end up with an aesthetic that would work well with your BL 3 and you'd get performance that would blow away the BL 11 - by a long shot. Yes, I have the BL 11 in my set up only because of how great it looks, if I wanted better sound, I'd get any other sub in a heartbeat.
My 2 cents worth. FWIW, I find the combo of BL 2 with either BL 8000/8002 or BL 3 to be a perfect match. They sound amazing to me. BL 2s are quite cheap right now, I have no idea why, but in the US they are 50% cheaper than a BL 11 (I guess form over function has a lot of value)
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
beojeff
USA
Posts 2,012
beojeff replied on Fri, Aug 28 2020 4:35 PM
Jaffrey2230:
I completely agree. I thought the BL3s sounded great for their size. When I added a BL2 to them, I was amazed at how the BL2 elevated them to an all new level. The improvement that a BL11 adds is very subtle.
beolion
Posts 485
beolion replied on Fri, Aug 28 2020 7:48 PM
I have the BL3 and BL2 combo and I really enjoy listening to music from the speakers.
I am using the recommended placement setting for it and the BL2 is adding the needed lows. Especially since our room is fairly large.
Michael
Atlanta
Posts 98
Michael replied on Fri, Aug 28 2020 9:16 PM
I like my BL3 and BL2 combo a lot.  However, I have them run from a Beosystem3 so the extra sound control could be a factor vs just running them through the crossover in the BL2 or a system with less control.
Chris Townsend
Qatar
Posts 3,531
OldJack:
I’m using it with a Beovision 10 at the moment, so I’ve no idea how to adjust it.
marexy
Posts 710
marexy replied on Sat, Aug 29 2020 8:18 AM
Maybe one interestng combo...BL8000 and LINN SIZMIK 10.25.
It takes some time to adjust..but end resolt is wauuu.
Page 1 of 1 (15 items) | RSS
